I am trying to convert VHS(pal movie) to VCD .For that ,I have a bt878 card.
I use iuvcr with Divx 5 compression (352*288 pal @ 25fps)and then TEMPGenc to convert to mepg1.I burn the cd with NTI CD Maker 5.
Although the mpg output is less brighter (perhaps due to compression) the quality is satisfactory when played on pc. But when I play it on a vcd player although I get the brightness back the image is dirty. I have tried to change some parameters like compression, color format without success
Please help me
Thanks Nawaaz[/u]
The image might be "dirty" because of the low constant bitrate of a VCD. Constant Bitrate usually makes blocks appear in files. Macroblockage occurs when there is not enough bitrate to process for your frames or scenes.
Hope That Helps!!!:P
You should be capturing using a less lossy codec then DivX. If your card supports it, try using either HuffyUV or MJPEG.
Oh.. and the quality of the video really is just as bad on your PC. Try playing it full screen rather then in a window to see what I mean.
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 04:48 -
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 09:41 -
Good or Bad ? at Verbatim 97016
By texmexdeaf in forum MediaReplies: 2Last Post: 13th Jun 2010, 01:03 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 03:18
